Relay wiring - Toyota Nation Forum : Toyota Car and Truck Forums
Old 09-24-2005, 09:49 PM   #1 (permalink)
touringcamry's Avatar
Gameroom cash: $550825
Relay wiring
I am not familiar with relays and just want to make sure I am hooking up this relay correct. I want to use the remote wire from my stereo to run a couple things. I am using this relay so I don't burn out the HU and will draw power directly from the battery.
I drew this diagram from the back of the packaging of the relay.
My understanding is that when the coil is powered, it will throw the switch so I should connect the remote wire to one end of the coil and ground to the other. The remote wire will power the coil and throw the switch.
The com pin should be connected to power and the Normaly open pin should be connected to the positive connection of what I want to turn on when the HU turns on. When the switch is thrown by the coil, this should complete the circuit on the positive end to run the device.
2007 Camry 2.4L 5M
Old 09-24-2005, 09:56 PM   #2 (permalink)
How Ya Like Me Now?
View Anshu's Photo Gallery
have you bought your relay yet?
your concepts are correct, but the application is a little differernt
the relay has 4 pins on it which are the contacts, get those hooked up right and dont worry about the coil etc.
98 V6 XLE
Dell 5100|SB Extigy|PPI DCX 730|NEXT 4.00|Monitor 2.70|ED Nine.1|LPG 26||Alpine Type R|ED 11ov2's and some other junk
Anshu is offline   Reply With Quote
Old 09-24-2005, 10:40 PM   #3 (permalink)
I have the relay already. It actually has 5 pins, but I won't be using the normally closed pin. I'll put some electrical tape over it.
What do you mean that the application is different?
2007 Camry 2.4L 5M
Old 09-24-2005, 10:51 PM   #4 (permalink)
How Ya Like Me Now?
ah
i was just saying that in the few times that ive wired one up, if just worried about getting the numbers right,
is the relay numbered?
98 V6 XLE
Old 09-24-2005, 11:13 PM   #5 (permalink)
There's no markings on the relay other than on the top where it has some part numbers and voltage markings. This is not one of those relays normally sold as "automotive relay" that is a little black cube and has 4 or 5 1/4" tabs on the bottom.
I just needed to make sure I knew what I was I was doing.
2007 Camry 2.4L 5M
Old 09-24-2005, 11:20 PM   #6 (permalink)
How Ya Like Me Now?
thats weird, there should be some near the tabs
when i wired my first one up, i got a 9v battery and a test light. Best way to learn IMO
98 V6 XLE
Old 09-25-2005, 01:57 AM   #7 (permalink)
I have a 12 power adapter somewhere, I'll mess with that first and my multimeter since I don't have a test light. The coil needs 12 VDC.
Thanks.
2007 Camry 2.4L 5M
Old 09-25-2005, 10:02 AM   #8 (permalink)
Grenaded piston
88 LE's Avatar
View 88 LE's Photo Gallery
Correct.
One end of the coil has to be positive (remote turn on lead from hu) and the other has to be negative (ground).
It doesn't matter which side of the coil is positive or negative.
Yup.
You can connect the com (common) pin or normally open (NO) pin to constant +12V. It doesn't matter which pin is connected to constant +12V, since these 2 pins connect together when the relay is triggered.
Just don't connect both to constant +12V.
That would be a SPST (single pole single throw) relay.
Theres also SPDT (single pole double throw) relays, which have 5 pins.
You can use either one. Just that on the SPDT relay, one of the pins is not used.
http://www.nteinc.com/relay_web/R51.html
"Skoolin' the unlearned!"
Old 09-25-2005, 09:22 PM   #9 (permalink)
The relay I have is SPDT. I just won't be using the normally closed pin.
The relay not like those ones that you provided a link to. It is slightly larger than one regular 4x2 Lego block.
2007 Camry 2.4L 5M
Old 09-27-2005, 07:40 PM   #10 (permalink)
The relay is going to piggy back off of the constant +12V and remote wires on the amp, read in parallel. The constant +12V has a 80A fuse by the battery and is 4AWG.
Since I'm going to be wiring up this relay with 18 AWG wire is it a good idea to put a fuse on the 18 AWG wire between the amp and the Com pin on the relay. The contact on the relay is rated for 10A @ 24VDC. I will need 4W @ 12V so a 500ma fuse should suffice I think. Is this neccessary or just redundant?
2007 Camry 2.4L 5M
Old 09-27-2005, 10:53 PM   #11 (permalink)
How Ya Like Me Now?
i would, what are you wiring up
Always better to be safe then sorry
98 V6 XLE
