Toyota Highlander JBL amp removal help! - Toyota Nation Forum : Toyota Car and Truck Forums
Old 09-30-2005, 11:00 AM   #1 (permalink)
View madclicker's Photo Gallery
I'm trying to install an after market unit on my highlander. Can someone tell me where the external JBL amp is located in the highlander? What needs to be removed? I removed the glove box and didn't see it. There is a small black box by the shock sensor but I don't think that is the amp. So, I was not able to find it . Thanks a lot!
madclicker is offline   Reply With Quote
Old 09-30-2005, 02:15 PM   #2 (permalink)
touringcamry's Avatar
Gameroom cash: $550825
If you pull out your stereo and there is two white plugs back there, not hooked up to your stereo, those plugs will bypass the JBL amp and you won't have to worry about removing it. The two plugs have 13 and 6 pins on them IIRC
If you have a stereo with an external amp, your stereo should have one white plug in the back with about 20 pins on it.
2007 Camry 2.4L 5M
Old 09-30-2005, 05:07 PM   #3 (permalink)
touringcamry,
Yes, my Highlander only has one 20 pin connector going to the radio. I have the external amp, I just need to find it so that I can bypass it. Any help with bypassing the external amp would be greatly appreciated.
Old 09-30-2005, 06:04 PM   #4 (permalink)
cam2Xrunner's Avatar
http://www.toyotanation.com/forum/t97292.html
Old 10-01-2005, 11:57 AM   #5 (permalink)
Iceman91's Avatar
View Iceman91's Photo Gallery
what kind of hylander do you have????
I have an 06 hybrid and my amp was under the tire jack in the back.
Iceman91 is offline   Reply With Quote
Old 10-01-2005, 12:18 PM   #6 (permalink)
The 03 doesnot have the amp there. Any other ideas?
Old 10-01-2005, 02:50 PM   #7 (permalink)
OK, I found the amp behind the back seat. Now, if I want to bypass the amp, which connector do I need to use? The 14 pin or the 16 pin connector for my speakers?
Old 10-01-2005, 06:43 PM   #8 (permalink)
Is there two white unused plugs behind the HU?
They should look like they will mate with these two connectors. This shot is from the back of my stock HU w/out JBL amp. If you have these two connectors behind your HU, it will bypass the JBL amp for your and you won't have to mess with taking out the JBL amp.
2007 Camry 2.4L 5M
