91 tercel speakers - Toyota Nation Forum : Toyota Car and Truck Forums
Old 10-03-2005, 01:07 PM   #1 (permalink)
View Black65Notch's Photo Gallery
91 tercel speakers
ok so ive been able to successfully installed a new d player in my car but i noticed that although there are wires for rear speakers, there arent any in the back, so my question is where are the wires in the back? do they even go to the back? any threads to a wiring diagram or helpful hints would be greatly appreciated.
Black65Notch is offline   Reply With Quote
Old 10-03-2005, 01:23 PM   #2 (permalink)
cam2Xrunner's Avatar
Helpful hints-Don't worry about the rear, focus on the front speakers. imo, Toyota saved you the time from ripping them out (I don't like rear speakers, it's all about the front end)
That's all I can offer
Welcome to TN
Old 10-03-2005, 02:27 PM   #3 (permalink)
TO Refugee
View ShowCarTercel's Photo Gallery
There are wires back there. You just have to take out the rear deck to find them. But first you have to remove the brake light cover. (Not sure if you need too, but it makes it easier) The rear deck just pops off. Fold down your back seat and then you can get it there no problem.
Match the wire colours with the wires found up under the dash if you aren't sure which ones they are. But it should be pretty easy to tell, just look for the two plugs near the speaker holes that aren't pluged into anything.
Manitoba's First and Only JDM 5efhe Powered Tercel.
It's Running Now!!!
ShowCarTercel is offline   Reply With Quote
Old 10-03-2005, 04:34 PM   #4 (permalink)
sweet! ill check it out
Old 10-27-2005, 12:02 AM   #5 (permalink)
View XKWISIT1's Photo Gallery
The wires for the rear speakers are there. The are taped up under the rear deck. If you lift up the rear deck you will see the there.
XKWISIT1 is offline   Reply With Quote
