Toyota Nation Forum : Toyota Car and Truck Forums - View Single Post - 89 camry starting troubles...help!
View Single Post
Old 01-29-2006, 11:11 PM   #12 (permalink)
PoR2GeEzCamry
View PoR2GeEzCamry's Photo Gallery
Yea i checked the oil level. It was full. I replaced the oil pressure switch, which i suspect is the same as the oil pressure sensor. The new one i bought was a little different then the one that was previously on there. The new one is a little longer. Would that make a difference? Ill check if the oil filter is on tight enough, and see if it is indeed the correct one. Im sure it is though.
Another thing i notice is that under the car you can see that oil has leaked while its been sitting there. Its a pretty large area. It leaked before this happened too though. Could this oil that leaked be connected to the problem here?
PoR2GeEzCamry is offline   Reply With Quote
