Re: garages really bother doing this ?
The message <pan.2006.01.30.09.16.30.96949@nospam.thankyou.says_I.ko>
from gazzafield <rufty_tufty_hoolythug@nospam.thankyou.says_I.ko>
contains these words:
[color=blue][color=green]
> > It's only a /coating/? How on earth do they justify such a high price
> > for just plating them? I'd expect a bloody thick layer for the amount
> > they cost.[/color][/color]
[color=blue]
> Because IIRC, platinum is the most expensive metal in the world?[/color]
Not by a long way, a little over a thousand dollars an ounce. You could
probably get a couple of hundred solid plug-tips out of an ounce, but if
the coating's so thin it can be damaged by adjusting the gap then
someone's being ripped off.
Skipweasel
Si hoc legere scis nimium eruditionis habes.
