Toyota Nation Forum : Toyota Car and Truck Forums - View Single Post - Need help with my Gen 5 Camry
View Single Post
Old 02-04-2006, 07:18 AM   #3 (permalink)
88 LE
Grenaded piston
88 LE's Avatar
View 88 LE's Photo Gallery
The door pin switches use a negative trigger. In other words you have it hooked up wrong.
Tie the positive lead to constant +12V. And the negative lead to the door pin switch or the door trigger wire (I have no idea where it is on a gen 5 though).
Door trigger wire is also negative trigger, but it outputs whenever any door is open. The door pin switches only work for the door its tied to.
Is there just 2 wires on the footlight kit?
"Skoolin' the unlearned!"
