Originally Posted by terrynham
from what i can figure, Toyota says the stock headunit does 140W, and looking at the speakers it says 12W on the base...(whether these figures are true or not is beyond me  )
so with changing the speakers, is it a plug and play sort of thing? or do i need to start thinking about amps and all that stuff? because id rather not get into that if at all possible.
The 140W rating is probably the total of the peak wattage values. You have 4 channels so that's about 35W x 4 peak. Peak wattage is typically a bit more than twice RMS so 12W may not be very far off from the RMS output of each channel from the head unit. I don't know the output of the stock stereo, but I would suspect it's somewhere between 12-18W x 4 RMS.
but, if i put 10W of power into each of those speakers, will the loudness of each be more or less the same? (even though their maximum outputs are different)
It would depend on the sensitivity of the speakers but I don't have any specs to say for certain. I would not expect the aftermarket speakers to be significantly louder with the same wattage. However, the sound quality will be improved.
