Toyota Nation Forum : Toyota Car and Truck Forums - View Single Post - xb sputtering
Thread: xb sputtering
View Single Post
Old 02-08-2006, 03:22 PM   #4 (permalink)
HATEnFATE
Let me out of my cage....
HATEnFATE's Avatar
Gameroom cash: $163450
View HATEnFATE's Photo Gallery
First, make sure you let your car get up to operating temp because it will always run rich if it doesn't warm up and that can cause problems in the future. Short trips means your car never warms up and the exhaust doesn't get hot enough to burn off condensation. Short trips can REALLY shorten the life of your exhaust system because water will sit in your pipe and rust it from the inside out. It might take a while to happen but eventually it will.
Stepping on the gas pedal shouldn't do anything until you actually get the car started. Older carburated cars would need a quick step in the throttle to get a little fuel in the engine for it to fire. On a fuel injected car like your box, when you turn the key you should be able to hear a little humming noise for a second. That is your fuel pump activating to get your system pressurized and get gas to the engine for you. stepping on the pedal wont do anything until the car is actually running.
Another thing to take note of, however, is that if your vehicle has trouble starting, everytime you turn your key fully off and fully on again, you've put more gas into your engine and can cause it to "flood." Make sure if your car is hesitating to not cycle the key to many times. You can stop cranking it without turning the key to the off position.
have your local dealer check your MAF sensor. I've seen a few xB's have faulty MAF's including one that wouldn't start at all and had to be towed in from 60 miles out.
"Fools", said I, "You do not know, silence like a cancer grows.
Hear my words that I might teach you. Take my arms that I might reach you"
But my words, like silent raindrops fell, and echoed, in the wells of silence.....
Jason Johnston
Toyota/Scion of Des Moines
(800)342-7045
HATEnFATE is offline   Reply With Quote
