What size socket did he use? Did he use a spark plug socked or a regular socket? Spark plug sockets are thin wall and are made for tight areas. Not all regular sockets are. Did you mean the socket fits the replacement plug?
Is there a reason he's changing the plugs? These plugs are good for 120,000 miles. You shouldn't need to change them yet, unless you drive for a living.
If the plug was stripped from the factory then the car would not have run properly so if it's stripped, its most likely because of your son.
From the sounds of it you'll either have to continue to try to get it out or take it(tow it) to the nearest repair facility and have it repaired properly.
"Fools", said I, "You do not know, silence like a cancer grows.
Hear my words that I might teach you. Take my arms that I might reach you"
But my words, like silent raindrops fell, and echoed, in the wells of silence.....
Jason Johnston
Toyota/Scion of Des Moines
(800)342-7045
