Well there Bobo, Not all dealers are like that but thanks for the vote of confidence.
The reason your xD quits wanting to die when you put it in park or neutral is that you're taking the "load" or restraint off of the engine when you do that so there is no drag coming from the transmission.
My first quiestion is now many miles are on your xD? Do you still have any warranty remaining? Keep in mind that this is possibly a powertrain issue and might be covered by the 5 year/60,000 mile powertrain warranty.
I do agree that doing some kind of a fuel flush might help the situation.
You might have an ignition coil starting to go out(it's a problem with the xB's though the engine's are not related and the coils are different)
There might possibly be an issue with the Mass Airflow Sensor. It might be a little dirty from the salt in the air if you are close to the ocean. It might just need to be cleaned/replaced.
The Throttle Body might be in the same situation as the Mass Airflow Sensor. Maybe some salt has crystalized on the inside of it, causing a port to become partially blocked?
I can think of a number of small things that could cause a "stumbling" issue like you are descibing. Not many of them are likely however if your car isn't setting off a "check engine" light or MIL(malfunction indicator lamp) as toyota refers to it. Since there is no light, whomever is looking at the car, be it a Toyota technician or a local mechanic that you trust, finding the problem will be a little difficult because there isn't a cut and dry spot that the car is telling him/her to look first.
Make sure when you take the car to Toyota, you tell the service advisor exactly what happened, when it happened, and what happened when you put the car in park/neutral.
P.S. Do NOT put in any fuel additive because it might make the problem harder to diagnose.
"Fools", said I, "You do not know, silence like a cancer grows.
Hear my words that I might teach you. Take my arms that I might reach you"
But my words, like silent raindrops fell, and echoed, in the wells of silence.....
Jason Johnston
Toyota/Scion of Des Moines
(800)342-7045
