Toyota Nation Forum : Toyota Car and Truck Forums - View Single Post - A few questions on the Gen 2 camry and st18x celica
View Single Post
Old 02-15-2006, 10:05 AM   #6 (permalink)
88 LE
Grenaded piston
88 LE's Avatar
View 88 LE's Photo Gallery
Originally Posted by Covert_operatoR
My bad, so what does the ECT control?
ECT = electronic controlled transmission.
Theres a switch behind the e-brake lever that says normal and power. And theres also a ECT ECU buried under the dash.
With the switch in "power", the transmission holds a gear longer before it upshifts to the next gear.
anyone know if the seats from a st18x celica or ae86 fit onto the camry seat runners without modification?
I doubt it, so modification is probably required.
If you know how to weld and fabricate, its not a big deal
also, I've seen automatic transmission oil cooler kits, anyone have experience with them? and know if they truly do help? I'm under the impression its more of a precautionary thing, but would it indeed increase the longevity of the transmission with the abuse its now subject to?
Yes, they help. However if your transmission is failing, nothing is going to save it from failing.
With that said, if your looking into one, get one with bar and plate (also called stacked plate) construction.
http://www.bmracing.com/index.php?id...bcat=28&pid=73
"Skoolin' the unlearned!"
