Originally Posted by Troyfrezze
The tweeters came with a capacitor, I assume to act as a High Pass filter. I found somewhere that I can then wire the tweeters to the door speakers, as long as I put the cap. in series with the wire.
That's correct. Most tweeters don't come with this capacitor.
You will need two seperate channels of amplification for them though.
If at any way possible you can return your front coaxials and tweeters, you would be better off using the money of the two for an actual component set.
