Re: 99 toyota corolla - stuck in snow - coolant issue?
There should be a rubber tube near the radiator cap and if you trace
that it should end at the resevoir.
The best way to find a leak is while the engine is cool, use a radiator
pressure pump device which puts about 20 pounds of pressure in the
radiator. This will swell the hoses up and pinpoint hard to find leaks.
Don't have this device ? Something else I tried if you have an air tank
is to only put about 20 pounds of pressure in it and if it has a valve
to slowly leak air out attach it to the overflow hose at the resevoir
side. This will also show any leaks. Just be sure you don't go over 2o
PSI. Hope this helps.
J
toyota owner wrote:
[color=blue]
> Actually, when I have put wiper fluid in, I've looked to see if there
> was a coolant resevoir, but haven't ever seen one. I looked again
> today when I put wiper fluid in and noticed that I didn't see one.
> So, I'm assuming it's only in the radiator. Which seems odd to me.
> How do you know when to put more in and how the heck do ya do it?
> Thanks for the response. It is greatly appreciated.
> -Samantha
>[/color]
