Re: 99 toyota corolla - stuck in snow - coolant issue?
"Joey" <J_nospam_lancos@moultriega.net> wrote in message
news:11vabkb3b4jea95@corp.supernews.com...[color=blue]
> There should be a rubber tube near the radiator cap and if you trace that
> it should end at the resevoir.
>[/color]
Good advice!
[color=blue]
> The best way to find a leak is while the engine is cool, use a radiator
> pressure pump device which puts about 20 pounds of pressure in the
> radiator. This will swell the hoses up and pinpoint hard to find leaks.
> Don't have this device ? Something else I tried if you have an air tank
> is to only put about 20 pounds of pressure in it and if it has a valve to
> slowly leak air out attach it to the overflow hose at the resevoir side.
> This will also show any leaks. Just be sure you don't go over 2o PSI.
> Hope this helps.
> J
>[/color]
I am not a fan of pressure testing radiators because the pressure tester
itself can cause leaks. It is not so likely on a well-maintained cooling
system but I prefer to use my eyes, fingers, and nose. So far, that method
has worked 100% of the time for me, and I've looked at my fair share of
problem cars.
Ray O
