Originally Posted by semdj
All the info I have received so far indicates a 4AGE swap, but the 4AGE is fuel injected.
Is there a 4AG which is carburated???????????? Carbuated would be alot easier swap.
if you want to run carbs on the 4A-G, you'll have to go with dual side drafts. it'll be more expensive believe it or not than making the EFI work on your car. also if you live in an area where there's so many different elevations you might have a hard time tuning the dual carbs. i've done the 4A-Ge with dual webers before and looking back now, there's actually more cons than pros when i did it.
my old set-up..
