Toyota Nation Forum : Toyota Car and Truck Forums - View Single Post - 2006 TUNDRA 4X4 AUTO LSD?
View Single Post
Old 02-21-2006, 06:04 PM   #11 (permalink)
Glenn Arsenault
Guest
Posts: n/a
View Glenn Arsenault's Photo Gallery
Re: 2006 TUNDRA 4X4 AUTO LSD?
The Auto LSD is not a real LSD but part of the Vehicle Stability Control
system. The Auto LSD achieves the equivalent functions of an LSD (Limited
Slip Differential) through the use of a traction control system. When the
driver presses the Auto LSD switch, this system achieves the LSD effect by
regulating the hydraulic pressure that acts on the drive wheels and
controlling the engine output in accordance with the amount of pedal effort
applied on the accelerator. Auto LSD tends to enhance the acceleration
effort somewhat, in order to apply greater drive torque to the wheel that is
making contact with the ground. Thus, this function enables the vehicle to
get unstuck if a wheel loses its grip, and enhances the vehicle's startoff
performance on high-resistance surface conditions such as gravel roads
"INDIVIDUAL" <NOT@NOT.COM> wrote in message
news:43fb5962$0$5694$9a6e19ea@unlimited.newshosting.com...[color=blue]
> It is a Limited Slip Differential (rear) (LSD) which is turned on or off
> with a dash button. The vehicle is a part time 4wd so I guess I should
> have said 4x2. My mistake.In any case I am looking for help on the Auto
> LSD button which as you stated you are not familiar with.Thanks for your
> advice on 4 wheel drive systems!
> "MrFixit469" <MrFixit469@verizon.net> wrote in message
> news:1140541074.427652.58220@z14g2000cwz.googlegroups.com...[color=green]
>> If it's FULL TIME 4 wheel drive, there's no option to switch to 4 wheel
>> drive and it's called 4X4. If there's a neat little button on the dash
>> to switch to 4 wheel drive, it's called 4X2. The 4 wheel drive button
>> is designed to get you out of jams, NOT to drive around daily with it
>> on. This will tear up the transmission, transfer case and differentials
>> as it's not designed for FULL TIME 4 wheel drive. This button is
>> designed to get you unstuck, steering straight ahead! If you drive
>> around turning corners with this on, it WILL tear up your front axle
>> and you'll hear awful noises coming from the same.
>> I'm not familiar with the LSD. It sounds like a suspension adjusting
>> device sensitive to loads in the truck. I'd imagine this is turned on
>> when hauling or towing stuff.
>>[/color]
>[/color]
