Originally Posted by SWTRDSPORT
STEPS #1-5
Find your light blue fog light relay, remove the relay and bend the top right pin from the relay to the side pointing outward, Attach a female spade (quick connect) connector to the bent relay pin. The other end of this wire will run to one side of a 5A fuse. Once you have your wire running from the relay to one end of the fuse, now run a wire from the other side of the fuse to the red 10A fuse that’s located directly to the right of the relays location.. Now you’ve completed this modification. Something you might note doing this modification this way, I’ve heard that in some cases if the fog light button is left on, your fog lights will sometime have a tendency to flicker on/off after 4-6 hours of sitting. The fog lights evidentially will come on for a minute or so then turn off repeating this process every 4-6 hours…
OPTION #3: FINAL PRODUCT/LOOK
Original image taken from Pb2theMax from Toyota Nation.
One correction on that last part of the paragraph. The lights will not come on every 4-6 hours. They will only come on once, 4 hours after the engine has been shut off. They won't keep coming on every 4 hours. At least in my experience.
