5.7 into a 2001 tundra - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Truck, SUV and Van Forums > Tundra Forum > 2nd Generation (2007+)
2nd Generation (2007+) Discussion of the 2nd generation of the Toyota Tundra
Old 06-26-2007, 08:23 PM   #1 (permalink)
View drmotorhead's Photo Gallery
I have a chance to buy my brother's 2002 Tundra that already has a 4.7 liter. I modify every vehicle I own, and I would like to swap the 4.7(240hp?) for the nice big 5.7 in the 2007 Tundra. Is the block/head/acessory design the same? Should I be able to install the 5.7 if I get the engine and all related components(computer, wiring, fuel pump, etc)?
2004 Toyota Sienna
1991 Acura NSX, 2710 lbs, 300 hp
1996 Ford Thunderbird Sport
drmotorhead is offline   Reply With Quote
Old 06-26-2007, 10:25 PM   #2 (permalink)
Precision driver
mhadden's Avatar
iTrader Score: 7 reviews
View mhadden's Photo Gallery
I don't see why not, but you are going to spend a boat load of money...remember, the 6-speed/5.7 setup is completely new, and I highly doubt the old tranny will match up with the 5.7 block...It'll just be cheaper to buy a new one.
2011 Fit Sport 5MT
2011 Pilot EX-L AWD
2008 Goldwing Navi
mhadden is offline   Reply With Quote
Old 06-27-2007, 11:29 AM   #3 (permalink)
"Completely new"? Did Toyota really design a totally new V8 from top to bottom? I expected that this was a bore and stroke version of the 4.7. Bolt patterns for a tranny dont tend to change very often, I hope they did not change it.
The new Tundra is just not the truck for me. Trucks(and cars) have gotten dramatically large and heavier over the last few generations. I cant find the numbers, but the I bet the new one is 1000lb heavier than the last generation.
2004 Toyota Sienna
Old 06-27-2007, 12:37 PM   #4 (permalink)
Mad Scientist-In-Training
toyrolla's Avatar
View toyrolla's Photo Gallery
Not sure about the 4WD versions, but here's the specs based on my 2001 Tundra
2001 Tundra SR5 - Standard Bed Extended Cab 2WD
GWV 2722 (kg) -> 6001 lbs
2007 Tundra SR5 - Standard Bed Extended Cab 2WD
GWV 2903 (kg) -> 6400 lbs
Even though the 2007 body is larger, it's only 400lbs more.
Regards,
Toyrolla
__________________________________
88 I4 Slushie *sold*, 89 I4 5Sp *sold*, 89 V6 5Sp *sold*, 82 Corolla, 72 Datsun 510, 88 Toyota Minitruck.
toyrolla is offline   Reply With Quote
Old 06-27-2007, 02:31 PM   #5 (permalink)
you are quoting gross vehicle weight, which is the total weight of the truck fully loaded with passageners and cargo.
curb weight is without passengers and cargo:
first gen tundra:
Curb weight3935–4215 lb (1785–1912 kg)
I think it(wikipedia) gives a spread that covers the single cab to double cab 4wd.
2007 new tundra:
short cab, short bed, 5.7 v8
Curb Weight MT
N/A
Curb Weight AT
4890
Ground Clearance
10.2
Like I thought, about 1000lbs. Nothing wrong with that, but that bumps it up to a whole new class of vehicle.
2004 Toyota Sienna
Old 06-27-2007, 02:38 PM   #6 (permalink)
the biggest of the new tundras:
2007 Toyota Tundra 4X2 Limited Crew Max 6AT Technical Specs
Curb Weight MTN/ACurb Weight AT
5415 lbs
Wow. I can picture the next generation of new trucks:
The standard model should weigh 6500lbs, tow 15,000 pounds, and have three rows of seating. And get 9mpg. On a good day.
2004 Toyota Sienna
Old 06-27-2007, 07:05 PM   #7 (permalink)
EchoHoLiK's Avatar
View EchoHoLiK's Photo Gallery
The 4.7L is a UZ block, whereas the 5.7L is a UR block, hence a different design and I don't think they're interchangeable.
EchoHoLiK is offline   Reply With Quote
Old 06-28-2007, 03:41 PM   #8 (permalink)
thanks for specifying the difference in the blocks. Too bad. That would be a great swap if it was easier.
2004 Toyota Sienna
Old 07-01-2007, 09:18 PM   #9 (permalink)
stryker709's Avatar
View stryker709's Photo Gallery
5415 lbs
Except they seem to keep increasing hp with mpg as good or better. Also theyll all come standard with 24 inch rims.
Stryker
07 Silver double cab, trd, 5.7l, 4x4
K&N Air intake, Zoomers 304 ss catback
All steel tool box topper. HD ladder rack. Makes one sweet work truck. Calgary, Alberta.
stryker709 is offline   Reply With Quote
Old 07-03-2007, 10:00 AM   #10 (permalink)
toyrolla's Avatar
Question
Would headwork to improve the flow fare as a better option as opposed to the swap?
Regards,
Toyrolla
Old 07-04-2007, 11:09 AM   #11 (permalink)
milnersXcoupe's Avatar
View milnersXcoupe's Photo Gallery
4.7 - 'the only choice' for High Perf. Builds' -
Toyota doesn't change Eng. to Trans. flanges for no reason - it's been Std. fare
for a long time.
My monies say Yes - a 5.4 will bolt into a 4.7 engine bay and bolt to the existing
transmission using the 4.7 flexplate / convertor.
The engine bore centerlines are the same - but the cylinders are 'siamese'd - which tends to develop 'Hot Spots' - not great for High Performance.
Should you scrape up a cylinder bore - the 5.7 block cannot be 'over bored' - the block is now junk - you cannot 'sleeve' these blocks.
The big changes from the 4.7 to the 5.7
are the use of Timing Chains instead of gears between the cams and Chains instead of a single Timing Belt - the Bore is the same 94mm as the 4.7 - the Stroke has increased from 3.31" to 4.02" - can't tell you about the cam specs as yet.
The cylinder block 5.7 is all Alum. - the 4.7 is high quality compressed graphite cast Iron , same material used in the NASCAR race engine cyl. blocks.
The VVT-i added 40HP to the 4.7 in '05-'06 with a boost in Torque specs as well.
The big question is the ECM controller for the 5.7 - as your 4.7 is not VVT-i technology.
Did the '05 - '06' VVT-i 4.7 use the same transmission as your '02 ? No.
You might look into having the 5.7 ECM reprogrammed for your transmission - feasible - but if you run across a 5.7 Engine / Trans. combo - then you'd be set.
www.Lextreme.com
Read here on the 4.7 engines - which I prefer over the 5.7, as they Rev quicker, have gears between camshafts and a single Belt rather than huge flailing timing chains heating and churning air bubbles into the Engine Oil.
The 'failings' of the 4.7 - only two - show up when people want 'more' from their engines - and add a Turbo or Supercharger without addressing the 'skinny' Powder Forged connecting Rods and Cast Alloy Pistons.
Toyota used these 'skinny' rods to lower the reciprocating weight - making the engine 'Rev Happy' - but - they are not designed to support Turbo / Supercharging - which is why TRD stopped offering Supercharger kits for these - rods were blasting holes in the block.
Replace the rods / pistons with the Forged units offered on www.Lextreme.com, use ARP bolts everywhere - and you're good to go for Forced Induction making 'crazy' HO / Torque.
I personally would use Turbo rather than Superchargers - as Aux. belt driven superchargers add wild 'Harmonics' to the crankshaft which hammers the bearings - and - Superchargers 'heat soak' an engine.
Use the JBA Stainless Steel Headers and put the Turbos at the ends of each - or - check
with Cowboy Bebop for a set of his forward facing headers he's making for 4.7 engines into SUPRA swaps - which will put the Twin Turbos forward of the engine - easier to plumb into an Intercooler that way.
The 4.7 has large intake ports - they are fine as they are - you could have the Manifold and runners Extrude Honed.
The cams are 'Torque' cams - again, fine - and do not need to be swapped out when adding a Turbo Kit.
I would pull your '02 4.7 out - put in Forged Internals - new water pump and Belt along with Timing Belt support items - install a Turbo or Twin Turbos - use a variable BOOSt controller so you can run around town on 8.5 or 9.5 pistons and spin up to 600 or 700 HP with the flick of the wrist.
I'd run a Methanol [windshield washer fluid 50/50] injection system that would kick in at 6lbs. Boost - protect against detonation when making 400 - 700rwHP.
Your next problem will be your Transmission handling 700 HP - IPT - Import Performance Transmission can help you there.
The 381HP 5.7 is an impressive engine - but the 4.7 is the 'choice' engine for a High Performance Build - full circulation of coolant around each cylinder - not 'Siamese'd cylinder bores.
Toyota used the 4.7 as the basis of their Indy efforts for awhile - heads / block / and at times the stock forged crankshafts.
The 4.7 also set track records in Drag Racing for 'Turbonetics' Celica Dragster.
The 4.7 engine block can handle 1,200 HP without modification - show me another stock production engine that has DOHC alloy heads making this amount of power simply by adding rods /pistons with a Turbo!
You've the best Toyota engine or any Engine for that matter, in your '02 for the Classic High Performance Hot Rod Treatment - so get reading 'n Enjoy !
www.Lextreme.com
milnersXcoupe is offline   Reply With Quote
Old 07-07-2007, 01:13 AM   #12 (permalink)
EchoHoLiK's Avatar
Thanks for such informative post milnersXcoupe
Add to the fact that the 5.7L is still relatively new, and the 4.7L is well proven for modifications. I guess if giving the new motor a couple of years, modified performance should catch up.
Can the 2JZ be considered another Toyota DOHC engine that can make that kinda crazy power (at least 1200hp) with minimal mods?
Toyota's new Tundra strikes fear among Big 3 toyotafanfan Toyota News 20 05-18-2007 08:52 AM
Fairly Comprehensive factory 0-60 times under 6 sec. Rdizzle General Discussion 15 04-09-2007 11:12 PM
2001 Tundra Access Cab CamryDriver Car parts for trade or wanted parts 0 03-05-2007 02:26 PM
( 2007 Tundra - USA Today ) + ( Tundra ~100% American ) RAV4EVR Toyota News 0 01-12-2007 03:58 PM
Official 2007 Toyota Tundra Announcement, Images & Specs EKam Toyota News 324 01-09-2007 11:54 AM
