Tire pressure questions - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Truck, SUV and Van Forums > Tundra Forum > 2nd Generation (2007+)
2nd Generation (2007+) Discussion of the 2nd generation of the Toyota Tundra
Old 08-13-2007, 06:55 PM   #1 (permalink)
View buckstom's Photo Gallery
I check my tire pressure all the time so I keep on top of it. I think that 30 lbs is way too little for a big ole tire like that. I pump it up to 35 lbs and it so rough that I can run over a dime and tell if it's heads or tails. It looks as though the front are wearing on the edges indicative of low pressure. Anyone else experiment with tire pressure?
buckstom is offline   Reply With Quote
Old 08-13-2007, 07:17 PM   #2 (permalink)
Precision driver
mhadden's Avatar
iTrader Score: 7 reviews
View mhadden's Photo Gallery
I run at 35 front, 33 rear with no problems. If it gets any worse, I'd take it to the dealer to souble check your alignmnt.
2011 Fit Sport 5MT
2011 Pilot EX-L AWD
2008 Goldwing Navi
mhadden is offline   Reply With Quote
Old 08-14-2007, 10:29 AM   #3 (permalink)
View nikita's Photo Gallery
You must rotate as recommended in the owners manual. Toyota, Ford and GM trucks I have owned all had steering geometry (yes, properly aligned) that tend to do that to the front tires. Over inflation, as you have noticed, does not fix it.
nikita is offline   Reply With Quote
Old 08-15-2007, 09:10 PM   #4 (permalink)
View Metrictundra's Photo Gallery
I run 32 front, 30 rear with no problems with only 1300 miles.
Metrictundra is offline   Reply With Quote
Old 08-23-2007, 10:52 PM   #5 (permalink)
Lion2655
View Lion2655's Photo Gallery
i let my tundra tell me when it need air with the air sensor.
Lion2655 is offline   Reply With Quote
Old 08-24-2007, 06:23 AM   #6 (permalink)
Precision driver
mhadden's Avatar
That system is no substitute for check your tires. The system probably won't even display the light until the tire pressure is below 26psi, and that low of a pressure could be enough to destroy your tire and/or cause a rollover in extreme manuvering...
2011 Fit Sport 5MT
2011 Pilot EX-L AWD
2008 Goldwing Navi
Old 09-02-2007, 06:43 PM   #7 (permalink)
wonger's Avatar
View wonger's Photo Gallery
neeed to rotate your tires more offen.. also running 35 psi does help.. u get a bumpy ride but your tires will last longer..
its because the new tundra has one of the best turning ratios in its class.. more turning ratio means more wear on the outside of the tires..
should ask most prius owners lol.. they buy more tires than anyone else
wonger is offline   Reply With Quote
Low Tire Pressure Indicator Reset FYI Wizrd23 5th & 6th Generation (2002-2006 & 2007-2011) 5 04-29-2011 09:43 AM
Is there a device that can pick up data from the tire pressure sensors and show PSI? bluemoose 5th & 6th Generation (2002-2006 & 2007-2011) 0 07-14-2007 10:49 AM
Tire Pressure Monitor Firephil Sequoia Forum 2 05-09-2006 11:48 AM
Pro Comp Tire Seperation Causes Crash Z71sc Feedback: Buyers, Sellers, and Vendors 0 10-19-2004 05:01 PM
Ractive Ram Air system. Camry_rider Hardcore Tech and Competition 51 07-23-2004 11:03 AM
