Towing Questions - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Truck, SUV and Van Forums > Tundra Forum > 2nd Generation (2007+)
2nd Generation (2007+) Discussion of the 2nd generation of the Toyota Tundra
Old 09-19-2007, 03:06 PM   #1 (permalink)
View dbevins's Photo Gallery
Towing Questions
I have 07 5.7L Tundra and will be towing a 5X10 motorcycle trailer that weight 2,120 lbs (trailer and motorcycle). What setting would you all recommend? Should I turn on the Tow/Haul Switch for example? Any input would be appreciated.
dbevins is offline   Reply With Quote
Old 09-19-2007, 06:03 PM   #2 (permalink)
Precision driver
mhadden's Avatar
iTrader Score: 7 reviews
View mhadden's Photo Gallery
It wouldn't hurt to use the tow/haul mode. It opens the butterfly valves up more and lets more air into the engine for better performance. Shift logics are also changed to better suit for towing.
2011 Fit Sport 5MT
2011 Pilot EX-L AWD
2008 Goldwing Navi
mhadden is offline   Reply With Quote
Old 09-19-2007, 08:40 PM   #3 (permalink)
07 Tundra DC 5.7 4WD TRD
Impelled's Avatar
View Impelled's Photo Gallery
Hey Dbevins, like he said...It won't hurt. With that little weight the truck won't notice it at all. Delaware Huh? I go to Alum Creek all the time and I've forgot to push the Tow/Haul button w/ a 5,000lb boat....didn't even feel it. You need a bigger trailer
07 SR5 DC 5.7 4WD TRD (White)
09 Corolla XRS 5spd M (White)
Impelled is offline   Reply With Quote
Old 09-19-2007, 11:05 PM   #4 (permalink)
View AZ29's Photo Gallery
The tow/haul button defaults off when you stop for gas. I often forget to re engage it when towing my camper. Mainly, IMHO, it holds the shift points to about 2500rpm instead of about 1500 or less when not engaged.
AZ29 is offline   Reply With Quote
Old 09-19-2007, 11:24 PM   #5 (permalink)
wonger's Avatar
View wonger's Photo Gallery
it just changes the shift points.. so the transmission doesnt keep shifting up and down due the the extra load..
its not an engine performance button .. doesnt change engine performance at all
88 4Runner
wonger is offline   Reply With Quote
Old 09-20-2007, 08:47 AM   #6 (permalink)
Precision driver
mhadden's Avatar
ERRRRR! Incorrect! Well, sort of, it doesn't add HP, but it does control the throttle valve...
8. Tow/Haul Control
General
During tow/haul control, the ECM controls the engine output, transmission shift schedule and shift timing to ensure drivability when a trailer is towed. The tow/haul control includes a throttle control, shift schedule control, wide open throttle shift timing control and AI-SHIFT control.
** The conditions required for tow/haul control to operate are as follows:
- Shift position: D position (Tow/haul control does not operate in the S position).
- TOW/HAUL pattern select switch: ON
** The TOW/HAUL indicator light is used to inform the driver that tow/haul control is operating.
Throttle Control
Throttle control changes the relationship between the accelerator pedal depression angle and the throttle valve opening angle.
** During tow/haul control, the throttle valve opening is increased by throttle control. As a result, acceleration performance is ensured.
Shift Schedule Control
The shift schedule control changes the upshift and downshift schedules during tow/haul control.
** For the upshift schedule, the upshift timing is changed to higher vehicle speeds, enhancing the use of lower gears. As a result, drivability is ensured.
** For the downshift schedule, the downshift timing is change to a wider throttle valve opening angle, enhancing the use of higher gears. As a result, the frequency of gear changes is reduced, allowing optimal shift quality.
Wide Open Throttle Shift Timing Control
Due to wide open throttle shift timing control, upshift timing is delayed to make use of high engine power when the accelerator pedal is fully opened.
** Wide open throttle shift control operates in 1st, 2nd and 3rd during tow/haul control.
11. AI (Artificial Intelligence)-SHIFT Control
General
In addition to shift pattern changes due to tow/haul control, AI-SHIFT control determines optimal transmission control based on input signals and automatically changes the shift pattern. As a result, a high caliber of transmission operation is achieved.
** The AI-SHIFT control includes a road condition support control and a driver’s intention support control.
** AI-SHIFT control is effect only with the shift lever in the D position, based on the accelerator and brake operation data. AI-SHIFT control will be canceled when the driver selects the S mode.
Road Condition Support Control
Under road condition support control, the ECM determines throttle valve opening angle and the vehicle speed whether the vehicle is being driven uphill or downhill.
1) When a trailer is not being towed:
** To achieve an optimal drive force while driving uphill, this control prevents the transmission from up-shifting to 4th, 5th or 6th gear.
** To achieve an optimal engine braking effect while driving downhill, this control automatically downshifts the transmission to 5th, 4th or 3rd gear.
2) When a trailer is being towed:
** To achieve an optimal drive force while driving uphill, this control prevents the transmission from up-shifting.
** To achieve an optimal engine braking effect while driving downhill, this control automatically downshifts the transmission.
** In addition to the shift pattern changes due to the road condition support control, the shift pattern is further changed when the tow/haul control is turned ON.
Driver’s Intention Support Control
1) When a trailer is not being towed Driver’s intention support control estimates the driver’s intention based on the accelerator operation and vehicle condition and selects a shift pattern that is well-suited to each driver.
2) When a trailer is being towed During tow/haul control operation, the driver’s intention support control ensures drivability while towing a trailer by determining the driver’s intention based on accelerator pedal operation and vehicle condition and performs the controls shown below:
Control= Sudden Accelerator Pedal Depress Control
Operation= When the driver operates (presses) the accelerator pedal quickly, this control causes the transmission to downshift rapidly to improve acceleration response.
Available for= 4th to 6th
Control= Sudden Accelerator Pedal Release Control
Operation= When the driver releases the accelerator quickly, this control makes it easy for the transmission to hold the gear, which improves engine braking force and re-acceleration response.
Available for= 3rd to 6th
Control= Sudden Deceleration Downshift Control
Operation= When the driver decelerates the vehicle suddenly, this control downshifts rapidly, which improves engine braking force and re-acceleration response.
---2007 Tundra "New Car Features" document
2011 Fit Sport 5MT
2011 Pilot EX-L AWD
2008 Goldwing Navi
Old 09-20-2007, 12:43 PM   #7 (permalink)
D1Boz
D1Boz's Avatar
View D1Boz's Photo Gallery
The only time I use tow/haul is when I'm climbing a steep hill or it feels like it needs it when I feel the shifting a little rough but that's usually never in this truck. I tow around a 6500lb camper but usually have the bed full of bikes, dog, wood, ect.
D1Boz is offline   Reply With Quote
Old 09-23-2007, 10:27 AM   #8 (permalink)
wonger's Avatar
sorrie.. when i said engine performance i meant HP..
88 4Runner
Old 09-24-2007, 12:37 AM   #9 (permalink)
Precision driver
mhadden's Avatar
Gotcha, misunderstanding...at least we are on the same page
2011 Fit Sport 5MT
2011 Pilot EX-L AWD
2008 Goldwing Navi
Towing question for an '04 PreRunner Red Dog 1st Generation (1995.5–2004) 5 07-18-2007 10:17 AM
Towing Package or Not? ForTech 2nd Generation (2005+) 16 04-06-2007 10:54 PM
3rd gen v6 4 runner towing questions?? -=\'][\' R [)=- 4Runner Lounge 2 11-14-2006 10:40 PM
99 engine vibration and towing questions. cashcrazy Archived Corolla threads 3 07-22-2006 10:38 PM
Towing questions... mcgrupp 2nd Generation (2005+) 13 01-04-2006 08:32 PM
