Water spots under mirrors after washing fix - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Truck, SUV and Van Forums > Tundra Forum > 2nd Generation (2007+)
2nd Generation (2007+) Discussion of the 2nd generation of the Toyota Tundra
Old 01-14-2008, 10:43 PM   #1 (permalink)
rvanders37's Avatar
View rvanders37's Photo Gallery
If you are obsessive compulsive like I am then you have noticed the white spots that form on your truck when you drive it right after it’s been washed. I suspected water was getting in behind the mirror mount somehow so I took the mirrors off to see what was going on. And I was right. The culprit is aluminum oxidation.
To get the mirror off first pull the triangle shaped cover off the inside. It will reveal the electrical connector and one of the mounting nuts. The remaining two mounting nuts are revealed if you pull the door panel away from the door. Nuts are in red circles below. I suppose you could use a wood block to keep it back. (Insert wood block at yellow arrow where my thumb is) whilst you remove the last two nuts.
And low and behold there was water getting in between the rubber gasket and the aluminum mounting bracket. You can clearly see the residue on the rubber below inside the red ellipse. The water was trapped in the aluminum cavity and it oxidized. That is what was causing the white spots on the paint. This is much more noticeable on dark color paint. It is also easily seen on the aluminum bracket
I first cleaned up the oxidation from the aluminum bracket and from the rubber gasket using a wire brush. Then I got some blue permatex gasket maker and laid down a thick bead along the edge of the aluminum bracket and on the rubber gasket. See the yellow arrows. for where to put the permatex.
If you are a real perfectionist, I guess you would paint the bracket with rustoleum and drill drain holes in the bottom of the bracket, but I didn’t go that far. Let the glue cure for about twenty minutes then have someone help you put the mirror back on the truck one to hold it and the other to fasten the screws. Having the person holding, to hold it still so the glue won’t get pushed off the bracket. We broke the plastic stud fixture (in red circle below)
on the passenger side but not to worry it’s just to hold the mirror until the nuts are secure. Be careful not to drop the nuts in the door because you will have to pull the door panel off to get them out…which is easy if you have too. Put everything back together in the reverse order and you are done.
You may wonder why I didn’t take this to Toyota to get it fixed since the truck is under warranty? I didn’t have the patience or time to have them hose it up or try to put some sort of sealant on the outside of the mount which as it turns out wouldn’t have worked. And I enjoyed fixing it myself. This was the first thing I found wrong on the truck and I got is in July 2007. Cost: $0.00. Time: 25-30 minutes of quality time with my son.
top man
rvanders37 is offline   Reply With Quote
Old 01-15-2008, 12:32 AM   #2 (permalink)
Radio, this is Unit 91...
eurohazard's Avatar
View eurohazard's Photo Gallery
That's pretty cool! I use an electric leaf blower to dry my Armada (especially around the mirrors) to avoid weeping. Nice fix.
1993 Camry LE 5SFE AT, 2006 Nissan Armada LE 4x4, 1971 Cadillac Coupe DeVille "pimp juice"
Toys: 2007 Coachmen 19FLB, 2007 Regal 1900 V6
I'm the biggest boss thatchu seen thus far! Baby, that's muh wi'zzard!
eurohazard is offline   Reply With Quote
Old 01-15-2008, 12:41 PM   #3 (permalink)
shelpdogg's Avatar
View shelpdogg's Photo Gallery
Excellent write-up...... I detail my truck every week and even use a leaf blower and tie a microfiber around the mirror to keep this from happening.....however it still does.........BIG long white line straight to the bottom of the door......
I'll try the fix and see how it works!!! Thanks!
BTW...first post.....hi everyone.
shelpdogg is offline   Reply With Quote
Oil in water '93 pickup, 22-RE fairlanegt428 89-95 Toyota Pickup/Hilux 4 02-20-2012 07:50 PM
The Free Mod Series: Part VII Cheap Water Injection Toysrme Camry & Solara Lounge 17 05-26-2010 02:13 PM
FUGGLIE WATER SPOTS! camryLI Camry & Solara Lounge 23 05-31-2005 03:27 PM
Hot water for Winter washing carcatz MR2 Forum 18 03-21-2005 06:43 AM
