Tire pressure Monitor TPMS - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Truck, SUV and Van Forums > Tundra Forum > 2nd Generation (2007+)
2nd Generation (2007+) Discussion of the 2nd generation of the Toyota Tundra
Old 01-26-2008, 06:53 AM   #1 (permalink)
View Frank T's Photo Gallery
I am thinking about getting some after market wheels for my truck but was wondering how that will effect the TPMS (tire pressure monitor system). If I decide not to buy new sensors for the aftermarket wheels are there any issues??
Thanks
Frank T
'08 Tundra 4x4 5.7 DC 8ft Bed
'70 Pontiac LeMans Sport Convertible 350 All original
'64 Chevy Nova SS 383cu/450hp (scaryfast)
Frank T is offline   Reply With Quote
Old 01-26-2008, 09:55 AM   #2 (permalink)
wonger's Avatar
View wonger's Photo Gallery
no issues. just get a blinking tire lighter.. not sure if it will go solid after a while.. might just take the bulb out for it.. .. not sure if the tire shop will let you since its the law in 08 to have them on all 08 models..
88 4Runner
wonger is offline   Reply With Quote
Old 01-28-2008, 02:55 PM   #3 (permalink)
nicely retired
View virg's Photo Gallery
What's the problem? Can't you just transfer the present senders in your wheels to the new ones?
virg is offline   Reply With Quote
Old 01-29-2008, 08:59 AM   #4 (permalink)
Im not sure how to put the sensors in the new tires. From the ones I have seen the tire needs to be dismounted from the wheel.
Either way I want to keep the steel rims for the winter and the new ones for the summer. Unless I buy new sensors, one set of wheels will be sensor-less.
Old 01-29-2008, 09:05 AM   #5 (permalink)
View nikita's Photo Gallery
Black tape over the light. You will need to remember to check tire pressures once in a while. This "nanny" device was due to the Ford Exploder Firestone tire fiasco.
nikita is offline   Reply With Quote
Old 01-29-2008, 11:43 AM   #6 (permalink)
Toyota Fan
View toysrvmanager's Photo Gallery
The sensors have indiviual id codes that are programmed into the TPMS ecu, if you ran two sets you would have to reprogram the truck every time you swaped your two sets of wheels. If your stock wheels are the styled steel wheels the sensors will be less likely compatible with after market rimes. Factory aluminum rims and the basic steel wheels use a different angle of sensor that will go into A/M wheels.
toysrvmanager is offline   Reply With Quote
Tire Pressure sensors 05 Highlander GH05 1st Generation (2001–2007) 8 10-31-2007 08:08 PM
Tire pressure questions buckstom 2nd Generation (2007+) 6 09-02-2007 06:43 PM
tire pressure masteryota1 3rd & 4th Generation (1992–1996 & 1997–2001) 7 08-26-2007 06:48 PM
Odd tire pressure? newenglander 2nd Generation (2005+) 1 08-19-2007 08:28 PM
ABS, Brake and Tire pressure warning lights on!!!! DarkArcanine Archived Corolla threads 10 01-22-2006 09:15 PM
