5.7L Oil Change tips - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Truck, SUV and Van Forums > Tundra Forum > 2nd Generation (2007+)
2nd Generation (2007+) Discussion of the 2nd generation of the Toyota Tundra
Old 05-31-2009, 10:18 AM   #1 (permalink)
View AZ29's Photo Gallery
The write up for a 5.7L oil change is excellent. I might add a couple tips that helped me.
1. I could not get sufficient grip with the 65mm autozone wrench, and I tried both the metal and the carbon fiber ones. They kept slipping and I couldnt get the cannister off.
2. Went to my Toyota dealer, and they sold me the factory cannister wrench PN 09228-06500-02. Not cheap.
3. It worked great. Took my micrometer and measured 63mm inside diameter-Hmmmm,no wonder.
4. Lastly, being a fairly easy to frustrate person, when I had the metal splash shield totally off, I measured carefully and put a 4 1/4 inch access hole directly until the oil filter. I then took some small black heater hose and cut it to fit around the hole,and sealed it with black silicon seal. Looks nice, and no more fooling around with the pan.
Great site here, thanks for all the Tundra information!
AZ29 is offline   Reply With Quote
Old 06-01-2009, 08:36 PM   #2 (permalink)
RONE's Avatar
Gameroom cash: $188970
View RONE's Photo Gallery
Thanks for the tips! I'm sure they will be helpful for some members looking to do their first oil change.
I still prefer to completely remove the oil pan, asI've found it comes off pretty easily on subsequent attempts. Plus it gives me a chance to check everything over for leaks while I'm underneath the engine.
RONE is offline   Reply With Quote
Old 06-01-2009, 09:56 PM   #3 (permalink)
THIS SPACE FOR RENT
humanoid's Avatar
Gameroom cash: $1000164
View humanoid's Photo Gallery
You could also put a Fumoto valve in place of your current drain bolt.
http://www.quickoildrainvalve.com/
This is my sig.
humanoid is offline   Reply With Quote
Old 06-02-2009, 08:22 PM   #4 (permalink)
GO RED SOX!
Dana_15's Avatar
Gameroom cash: $221706
iTrader Score: 9 reviews
View Dana_15's Photo Gallery
I got so pissed one day I removed the clips on my skid plate, it comes off real easy now
Dana_15 is offline   Reply With Quote
Old 06-04-2009, 09:02 AM   #5 (permalink)
RONE's Avatar
I'm looking forward to my next oil change, as I installed a Fumoto on the last change. Unfortunately I made the mistake of not getting one with the nipple attachment for a hose, so I'll still have to use a catch pan and then pour into some bottles. Anyone looking to install one of these, be sure you get one with the nipple!
Old 06-04-2009, 07:05 PM   #6 (permalink)
Stupid is stupid does
lotust's Avatar
View lotust's Photo Gallery
I still have yet to do my own oil change on the tundra. I dont have the wrench to remove the canister as well. this is my main cause for not doing my change.
295/65/18 Goodyear Duratracs:2.5" lift in the front with 1" rear Block
JBA single exhaust:HID's W/Led's inside:Nfabs
E&G grill insert:ARE Z topper:Overhead DVD for my son:Front DVD for me
lotust is offline   Reply With Quote
Old 06-05-2009, 05:05 AM   #7 (permalink)
GO RED SOX!
Dana_15's Avatar
^^^You are not missing anything buddy
Old 06-09-2009, 05:44 PM   #8 (permalink)
Every road's a playground
toyotaholic's Avatar
View toyotaholic's Photo Gallery
when you guys do your oil change do you just crawl underneath or drive the truck onto ramps??
toyotaholic is offline   Reply With Quote
Old 06-09-2009, 05:51 PM   #9 (permalink)
GO RED SOX!
Dana_15's Avatar
Its pretty easy to crawl under there
Old 06-11-2009, 11:24 AM   #10 (permalink)
RONE's Avatar
$3 at Walmart. Right next to the oil filters & oil.
I just slid underneath.
Old 07-08-2009, 12:34 AM   #11 (permalink)
View eastoy's Photo Gallery
Question
Sorry, newbie here with my 2007 Tundra I recently purchased. Anyway not sure I'm understanding how you put a "4 1/4 inch access hole directly until the oil filter" ? Did you drill a hole here? Is this to drain the excess oil from the oil filter before you remove the filter? Also, is this "black heater hose" you used is it permanently attached? If so, is there a valve? Sorry I'm not understanding this.
eastoy is offline   Reply With Quote
Old 07-08-2009, 06:09 AM   #12 (permalink)
GO RED SOX!
Dana_15's Avatar
^^Check out this thread:
DIY: Oil Change w/ pics 5.7L
It is not a spin on filter....
