The real factor to determine is the height of the trailer that you'll most likely be pulling. Measure the top of the ball flange from the ground, with the trailer level and even (make sense?) That will be the height you want the top of the ball coming off the truck hitch. If you have rear end sag from heavy tongue weight, you'll have to factor that in.
On my boat it calls for the top of the ball to be between 18 1/2 to 21 inches. Stock Tundra- 2in drop
You need to have the trailer as close to level as possible when towing.
07 SR5 DC 5.7 4WD TRD (White)
09 Corolla XRS 5spd M (White)
