Toyota Canada Tech. Services (TRD SC 2007 Tundra) - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Truck, SUV and Van Forums > Tundra Forum > 2nd Generation (2007+)
2nd Generation (2007+) Discussion of the 2nd generation of the Toyota Tundra
Old 02-27-2010, 05:13 PM   #1 (permalink)
View BEAST-TUNDRA's Photo Gallery
I am not sure that you all know of my delima; 13 misfires, since I installed the TRD Supercharger.Toyota Canada Tech. Services have told the Dealership to stop spending anymore time and money on my truck. The Master Tech. was told that the misfires are caused by my truck being lifted (ProComp 6") and also having bigger tires (35"). I have filed a complaint with Toyota Canada, and I requested proof of their theory.
Misfire Codes only occur in Cylinders 1,3,5,7
Last 6 misfires occured from Cyl. 1
Work Done
-new plugs
-swapped coils and injectors
-checked valve clearances
-pressure 195-200 Psi
-new hydraulic adjusters
-checked MAF & intake
-new ECU
-swapped VVT
So the question is, does anyone else with the same type of mods on their truck have this same issue?
For your reading enjoyment
http://www.tundrasolutions.com/forum...rvices-trd-sc/
Thank-you
BEAST-TUNDRA is offline   Reply With Quote
Old 02-28-2010, 06:01 AM   #2 (permalink)
GO RED SOX!
Dana_15's Avatar
Gameroom cash: $221706
iTrader Score: 9 reviews
View Dana_15's Photo Gallery
Wow!
Check out Tundratalk.net as well....
Dana_15 is offline   Reply With Quote
Old 02-28-2010, 07:58 AM   #3 (permalink)
I am posting on all forums to find another truck, with the same ordeal.
Thanks
07 TRD SC Tundra Ltd. 4x4 5.7L.
6" ProComp Lift
Nitto Terra Grapplers - 35"
Old 03-17-2010, 06:03 PM   #4 (permalink)
View adrianrog's Photo Gallery
So, why not put factory sized tires back on and see if it helps. If not, how hard is it to remove the 6" lift?
-Adrian
adrianrog is offline   Reply With Quote
Old 03-17-2010, 09:58 PM   #5 (permalink)
adrianrog
-Adrian
I tried to get a used set from the Dealership, but that did not materialized.
The good news is that Toyota Canada agrees that it is not the tires and lift. My case file has been reopened and some engineers are supposed to look into my issue. The Dealership has also agreed that my issue should be resolved also. So I would say things are looking up
6" ProComp Lift
