Originally Posted by alpha17c
This is incorrect information....The shim has nothing to do with stiffness..Thats the spring....Spring does not get changed...The metal shim is installed to prevent sticking at full throttle...Thats it.
If you really want a new pedal the correct way is to say you do like the appearance of the pedal after modifcation.
don't like the look of the cut up pedal..I will prolly do that when my time comes! But never can tell till I'm there and looking down at the pedal when it's done.
I hear you should take out any mats you have before you go in because they basically 'impound' them until you sign a waiver. Don't know.
While I do believe it's all a sham, the one thing I DO want is the software upgrade for throttle cutout on braking...I see no reason why the DBW throttle wasn't implemented that way from the outset.
