Design Flaw - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Truck, SUV and Van Forums > Tundra Forum > 2nd Generation (2007+)
2nd Generation (2007+) Discussion of the 2nd generation of the Toyota Tundra
Old 05-09-2010, 09:49 PM   #1 (permalink)
View reinvent's Photo Gallery
Design Flaw
http://forums.jlconline.com/forums/s...ad.php?t=52096
reinvent is offline   Reply With Quote
Old 06-08-2010, 10:06 PM   #2 (permalink)
verlaryder's Avatar
View verlaryder's Photo Gallery
Huge thread on this problem at http://www.tundrasolutions.com/forum...ction-pump-57/
verlaryder is offline   Reply With Quote
Old 07-10-2010, 04:50 PM   #3 (permalink)
OkSlim's Avatar
View OkSlim's Photo Gallery
Several threads about this on TT and TS.
SOme dealers are covering it , others are saying no dice.
If you raise enough hell with Toyota, they will change it.
You can also pull the unit and dry it out from what I have read.
The Blue Streak Slug
2008 Tundra TRD Offroad
OkSlim is offline   Reply With Quote
Old 06-14-2011, 02:32 PM   #4 (permalink)
View xsnrg's Photo Gallery
Seems like someone found the way around this issue:
John says:
May 19, 2011 at 12:04 pm
How to electronically bypass the AIP pump system.
http://www.tundrasolutions.com/forum...erride-1.1.pdf
xsnrg is offline   Reply With Quote
Old 08-05-2011, 07:06 PM   #5 (permalink)
View dieselpartsman's Photo Gallery
When I had a Ford, it had spark plugs that blew out of their holes. Ford pretty much ignored the problem. I had the pump/valve problem with my 2007 Tundra and the dealer and Toyota took care of it, altho I did catch the service manager trying to put the screws to me. Toyota rep has assured me that there is a new vendor making the valves. They aren't really fixing the problem, just making the valves less susceptible to corrosion.
dieselpartsman is offline   Reply With Quote
Old 08-21-2011, 04:24 AM   #6 (permalink)
View imzjustplayin's Photo Gallery
Toyota has this covered under their powertrain warranty and or emissions warranty. I just had this repair done to my Tundra no issue at all and it's a 2007 Model.
Extend the life of your tires and save gas by inflating your tires to the PSI as listed on your tire's sidewall. (Commonly 44 or 51 PSI) Subtract 10PSI from the number listed on sidewall for the rear tires of an unloaded pickup. Tire PSI rating is of a COLD tire.
imzjustplayin is offline   Reply With Quote
