With the cartridge filter, there's a plug you can take out and it drains out all the oil quicker. You have to replace the little plastic piece inside afterwards, however. Although it's faster to do it this way, I prefer to unscrew the cartridge filter a little bit and let it drain on its own. You have to be careful because if you unscrew it too far then the whole thing will drop and leave a mess everywhere. The filter itself is pretty long, about 6-8 inches if I remember correctly.
With disc brakes all around, I see that you're in New York. Keep an eye on the rear because in salty winter conditions those calipers go crappy really quick since they're not used as heavily as the fronts are.
6 speed manual 2011 Camry SE 2012 Honda Accord Coupe---1995 Ford Mustang---1985 AMC Eagle
