2007 Tundra front differential leaking. Help!!! - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Truck, SUV and Van Forums > Tundra Forum > 2nd Generation (2007+)
2nd Generation (2007+) Discussion of the 2nd generation of the Toyota Tundra
Old 07-21-2011, 06:29 PM   #1 (permalink)
View TXTSS's Photo Gallery
I've got a 2007 Tundra 4x4 with a 6" procomp lift and 35" Mud Tires. The truck has 46000 miles and suddenly developed a Leak from the Driver's side front differential seal. After three weeks in the shop and replacing the shaft, seal and bearing, my tech is at a loss. The seal is still leaking. The shafts don't seem to be in a bind at all and there is no apparent reason. He said he's out of ideas. Really need some help with this one. Anybody?
TXTSS is offline   Reply With Quote
Old 07-31-2011, 11:30 AM   #2 (permalink)
Do you feel lucky?
TrailDust's Avatar
Gameroom cash: $3632150
I recall there is a TSB for the Tundra regarding transmission fluid leaks, but I don't know if it's applicable to your situation. You might want to look up the TSB list for your model year Tundra and check it out.
2008 Highlander Base 4WD
2002 Avalon XL
TrailDust is online now   Reply With Quote
Old 08-04-2011, 12:19 PM   #3 (permalink)
Banned
View sonofa's Photo Gallery
I'm pretty sure that the differential is not the transmission, so won't apply.
The LIFT will *definitely* add strain to the diff, even if everything seems to be moving smoothly. The strain, while in motion, is probably enough to pull the shaft slightly off center. If the shaft isn't perfectly centered in the seal, it WILL LEAK. I am nearly 100% positive that the leak is related to the lift.
Precisely what bearing was replaced?
sonofa is offline   Reply With Quote
