Sporadic clicking sound - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Truck, SUV and Van Forums > Tundra Forum > 2nd Generation (2007+)
2nd Generation (2007+) Discussion of the 2nd generation of the Toyota Tundra
Old 08-11-2011, 10:02 PM   #1 (permalink)
View Yelp softly's Photo Gallery
Please help, this is driving me crazy and will soon cause a wreck if I don't find this noise.
I have a sporadic click in my new 2011 Tundra (only 6K). It occurs when the vehicle is first put into motion. It is a single click only, not a series of clicks. I want to clarify. It is a single click, but you will hear several in a row if you go over bumps or you may hear two clicks if you go around a sharp curve then straighten out. It seems to be coming from the console/ dash area. I cannot pinpoint it while I'm driving. It doesn't seem to be coming from outside the vehicle so I have ruled out the usual suspects.
I have taken everything out of the console. I have turned every accessory on and off. Doesn't matter, it still makes a click when starting in motion or turning.
I read one thread with a similar problem. They said the dealership fixed something related to the wiper motor and the click stopped. I will check this area tomorrow.
Any ideas?
Yelp softly is offline   Reply With Quote
Old 02-01-2012, 11:59 PM   #2 (permalink)
View Ckris's Photo Gallery
Check the main engine harness mount post that is welded to your firewall on the engine side of your glovebox.. The main engine harness is a black tape wrapped harness that has a plastic clip that slides onto the post... The inside of the clip is metal... When it is partially off or loose from the mounting post, it makes a tapping sound that you hear on bumps occasionally.. It's hard to spot because the harness looks secure but could have worked loose and annoys the hell out of you with a mysterious tapping from what seems to be behind the glove box.... My dealership could not find it but I did when I jostled things around in the motor compartment to see what was loose...
I cured it with an additional cable tie around the whole clip/harness/post assembly.. Hope this helps
Ckris is offline   Reply With Quote
