Battery was brand new at the time of the test, I mean like 1 day old. Also put the battery on a float charger prior to testing again this past month, and still noticed the issue. Finally got them to do a more close look at the vehicle, they put in another, brand new battery, conducted their tests which were minimal, said it was fine, I said otherwise. Finally consulted with a technician and spoke with him directly (opposed to service advisor), showed him my readings via the OBD-II scanner and how the voltages were sagging when I turned on the electrical devices, also pointed out a whining noise coming from the engine bay which I thought could be the diodes in the alternator which would explain the poor voltage control, he took in the vehicle again. Finally I get a call on Friday saying they did more tests and found the alternator to be bad and the source of the whining noise coming from the engine bay. Now they say they can't fix it because it's not under warranty even though this has been an on going issue. Damn piece of crap!
Extend the life of your tires and save gas by inflating your tires to the PSI as listed on your tire's sidewall. (Commonly 44 or 51 PSI) Subtract 10PSI from the number listed on sidewall for the rear tires of an unloaded pickup. Tire PSI rating is of a COLD tire.
