side mirrors - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Truck, SUV and Van Forums > Tundra Forum > 2nd Generation (2007+)
2nd Generation (2007+) Discussion of the 2nd generation of the Toyota Tundra
Old 10-18-2011, 04:05 PM   #1 (permalink)
View jeepin1977's Photo Gallery
side mirrors
i would like to find out how to remove the side mirrors on my 07 tundra. i need to install towing mirrors and the new mirrors have turn signals built in and my current ones don't will they work?
jeepin1977 is offline   Reply With Quote
Old 11-09-2011, 11:10 AM   #2 (permalink)
Do you feel lucky?
TrailDust's Avatar
Gameroom cash: $3632150
I searched the Tundra forum and couldn't find any past threads describing the process, but a Google search did turn up the following:
The side mirrors on your 2008 Toyota Tundra help you locate a trailer behind the truck, and also show you where other cars are on the road. In an accident, these mirrors can get damaged and may break off of the truck. To get back that visibility while driving, you'll need to replace the damaged mirrors with new ones, bringing back that safety feature. This process should take about 10 minutes to do per mirror.
Things You'll Need
3/8-inch ratchet and socket set
Replacement mirror
Difficulty: Easy
Instructions:
1. Open the door. Remove the triangle-shaped panel in the upper corner of the door by pulling it down from the top of the triangle.
2. Roll down the window. Unplug the power mirror harness by hand if you truck has power mirrors. Support the mirror in your hand while reaching inside the cab with your other hand. Unbolt the mirror from the door using the 3/8-inch ratchet and socket. Slide the damaged mirror out of the door and discard it.
3. Slide the replacement mirror into the door. Support the mirror while bolting it in place using the 3/8-inch ratchet and socket. Plug the mirror harnesses together if your truck has power mirrors. Push the triangular panel back onto the door until it snaps in place.
I'd recommend buying a factory service manual if you intend on doing this and other DIY work on your Tundra. Ebay should have some cheap copies to buy.
2008 Highlander Base 4WD
2002 Avalon XL
TrailDust is online now   Reply With Quote
