chirping sound in the front - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Truck, SUV and Van Forums > Tundra Forum > 2nd Generation (2007+)
2nd Generation (2007+) Discussion of the 2nd generation of the Toyota Tundra
Old 11-13-2011, 08:01 PM   #1 (permalink)
View dieselpartsman's Photo Gallery
I get a chirping sound from the front of the engine but only when it's cold out. I figure if it was a pulley or water pump, it would do it all the time, but it doesn't. Temp gets below 40 and it starts.
thanks
dieselpartsman is offline   Reply With Quote
Old 11-14-2011, 09:33 AM   #2 (permalink)
Do you feel lucky?
TrailDust's Avatar
Gameroom cash: $3632150
I'd check your belts and pulleys.
2008 Highlander Base 4WD
2002 Avalon XL
TrailDust is online now   Reply With Quote
Old 12-06-2011, 06:12 AM   #3 (permalink)
yep, old belt was the problem. and it wasn't the temp, it was moisture. thanks
Old 03-15-2012, 11:17 AM   #4 (permalink)
rvanders37's Avatar
View rvanders37's Photo Gallery
that is a well documented tundra problem for 2007 and early 2008. it's the drive belt tenisoner. it only chirps when it's cold. the new part has Teflon imbedded in the coil spring to eliminate the noise.
top man
rvanders37 is offline   Reply With Quote
