Toyota Nation Forum : Toyota Car and Truck Forums - View Single Post - 91 Previa driver door closed and locked....
View Single Post
Old 03-01-2006, 08:56 PM   #6 (permalink)
suprasman01
MKII Supra Guru
suprasman01's Avatar
View suprasman01's Photo Gallery
I used a throttle return spring cut it to length bent the ends around were needed and installed with looong needle nose pliers.
Springs----> $2.99 (pack of two will do Previa spring three times thicker gauge)
Needle nose pliers ----> you need a good long set anyway
Time -----> about a half an hour.
Not having to walk around to the passenger side and enter vehicle and shimmy behind over to drivers seat -------> PRICELESS
-Joel
1985 Toyota Supra 7mgte swap with SP61
1991 Toyota Previa
suprasman01 is offline   Reply With Quote
