Toyota Nation Forum : Toyota Car and Truck Forums - View Single Post - high idle on Previa
View Single Post
Old 03-05-2006, 04:30 PM   #15 (permalink)
outsider60
View outsider60's Photo Gallery
Hello, If you look under the vehicle, you will see the other end of the steel pipe and another tee also. The coolant hose goes into the egr valve.
Remove the coolant hoses from the steel pipe and with compressed air blow from the tee by the engine. I just did mine this Sat.
Works like new............ Hope this helps ............................JM
outsider60 is offline   Reply With Quote
