Re: Jolt Brake Problem Or Something else ??
Sounds like your cold idle speed is set too high. When "choke" is on
(i.e.engine cold) the engine speed is higher than when it s warmed up. Choke
is old carb term - guess its the cold idle speed with FI.
"Indu Prakash" <leolite1@sbcglobal.net> wrote in message
news:CR4Pf.26399$2O6.21964@newssvr12.news.prodigy.com...[color=blue]
> Corolla 2002 Automatic 46K miles
> When I first start the car and put into into forward gear then with brakes
> pressed then I get a small jolt .. I can repeat the jolting but putting
> the car in reverse gear and then back into forward gear. But after driving
> around for 10 minutes the jolt was very less. Any suggestions ?
> Thanks
>[/color]
