Re: Dimmer problem on a '97 Camry
"Pasha" <pasha.isu@gmail.com> wrote in message
news:1141790038.070337.170300@j52g2000cwj.googlegroups.com...[color=blue]
> Hi,
> I just bought a '97 Camry and when I was driving it at night I noticed
> that when I try to increase the brightness of the dash board, I can't
> see the speedometer, only one light is working - the one of the far
> right, so I only see part of the tachometer... It looks like I need to
> replace the other light(s) in the center of the dash board and on the
> left-hand side. I can't imagine that this would be a fuse or wires...
> What's the best way to fix that?
>[/color]
First, try turning the rheostat on the outboard side of the steering column
clockwise. If that doesn't work, then you have to remove the instrument
cluster to access the bulbs.
[color=blue]
> Also, I noticed that AC controls are not illuminated at all at night, I
> can only see the Defrost and the AC bottons. I can't see the controls
> for Low/High air flow or the Hot/Cold air control. Is this a design
> flaw or are these supposed to be illuminated wehn the lights are on at
> night?
>[/color]
They should be illuminated when the lights are on.
[color=blue]
> Thanks in advance.
> Pasha
>[/color]
Ray O
