Toyota Nation Forum : Toyota Car and Truck Forums - View Single Post - Dimmer problem on a '97 Camry
View Single Post
Old 03-09-2006, 12:32 AM   #11 (permalink)
Ray O
Guest
Posts: n/a
View Ray O's Photo Gallery
Re: Dimmer problem on a '97 Camry
"Gord Beaman" <gord@islandtelecom.com> wrote in message
news:jjbv02150sejf5m7l384f5jgrpj0gc8c74@4ax.com...[color=blue]
> "Ray O" <rokigawa@tristarassociatesDOTcomn> wrote:
>[color=green]
>>news:lh3v02tn1dl2dj2ids9cbrmlqvk4ms0nvq@4ax.com...[color=darkred]
>>>>"Pasha" <pasha.isu@gmail.com> wrote in message
>>>>news:1141790038.070337.170300@j52g2000cwj.googlegroups.com...
>>>>> Hi,
>>>>> I just bought a '97 Camry and when I was driving it at night I noticed
>>>>> that when I try to increase the brightness of the dash board, I can't
>>>>> see the speedometer, only one light is working - the one of the far
>>>>> right, so I only see part of the tachometer... It looks like I need to
>>>>> replace the other light(s) in the center of the dash board and on the
>>>>> left-hand side. I can't imagine that this would be a fuse or wires...
>>>>> What's the best way to fix that?
>>>>First, try turning the rheostat on the outboard side of the steering
>>>>column
>>>>clockwise. If that doesn't work, then you have to remove the instrument
>>>>cluster to access the bulbs.
>>> Is this a tough job Ray?...(I have one bulb out I think, can't
>>> see the gas gauge or the right side of that area at night)
>>> -Gord.
>>> (use gordon in email)[/color]
>>To be honest, I have not taken out an instrument cluster in a long time.
>>If
>>you can get at the screws surrounding the instrument cluster, you might
>>get
>>lucky and be able to pull it straight out. The trick is putting it back
>>together with no parts left over ;-)[/color]
> God yes, I'm famous for that, if I'd have kept all those excess
> pieces I'd have had enough to build another car by now... :)
> -Gord.
LOL! I've got odds and ends stashed all over the place. I should try
making a car out of it!
Ray O
