Toyota Nation Forum : Toyota Car and Truck Forums - View Single Post - How can I tell the difference?
View Single Post
Old 02-16-2003, 07:41 PM   #15 (permalink)
goodcookiedrift
Banned
View goodcookiedrift's Photo Gallery
compatibility isn't an issue.
other than internal parts, and some accompanying mechanical parts, the engines are pretty much the same.
the only differences i've encountered are in the distributor, cams and valvetrain (obviously) and clutch/flywheel.
other than that, your oil pump, water pump, alternator, oil pan, etc. should be the same.
if its a 7rib block that you have, tell the parts guy you need "such and such" for a 91 4age. you know for a fact that the 91 ae92 came with a 7 rib block. if you need stuff for the head, tell them you ned "such and such" for a 1985 tvis head.
if you order the wrong part from toyota, if you're on a good rapor with the parts people, they will most likely let you return the aprt in exchange for the proper one.
nick
goodcookiedrift is offline   Reply With Quote
