Toyota Nation Forum : Toyota Car and Truck Forums - View Single Post - how to remove rust from brake drums
View Single Post
Old 03-10-2006, 05:15 PM   #5 (permalink)
Gary L. Burnore
Guest
Posts: n/a
View Gary L. Burnore's Photo Gallery
Re: how to remove rust from brake drums
On Thu, 9 Mar 2006 20:18:30 -0500, "CCA" <calexander@interhop.net> top
posted like an ignorant fucking moron and wrote:
[color=blue]
>Get them turned on a brake lathe.[/color]
Yeah, that'll help. NOT.
[color=blue]
>"Ray O" <rokigawa@tristarassociatesDOTcomn> wrote in message
>news:21b2c$440dc853$44a4a10d$20123@msgid.meganewsservers.com...[color=green]
>> <shirish.manjrekar@gmail.com> wrote in message
>> news:1141750760.555984.275380@p10g2000cwp.googlegroups.com...[color=darkred]
>>> Hi,
>>> Bought a used Corolla, 2001 @ 41K miles last year in April. It is
>>> currently @ 55K miles. The rear drums have a lot of rust all over.
>>> The rear brakes work just fine and so does the parking brake. I would
>>> like to get the external surface cleaned thogh.
>>> What is the easiest way to get rid of the rust apart from using a sand
>>> paper. The reason is a sand paper would be a pain to use to get at the
>>> rust between the cooling fins.
>>> Any place i could get them sand blasted. Rather the question is what
>>> kind of a shop to look for to get it sand blasted.
>>> Any alternatives?
>>> Plan to do it this weekend as the weather forecast says its going to be
>>> warm and sunny here in central NJ.
>>> Appreciate your feedback.
>>> Regards.
>>>[/color]
>> Light surface rust on the exterior of the drums is more cosmetic than
>> functional. Sandblasting the drums may cost more than replacement drums,
>> and before paying someone to sandblast the drums, I'd measure the inside
>> diameter to see how much life is left. Machine shops and auto body shops
>> usually have sandblasting cabinets.
>> If you have a good size air compressor at home, you can get a small
>> sandblasting kit or you can get a wire brush attachment for a drill. When
>> using wire brushes with a power tool, make sure you wear eye protection!
>> Ray O
>> (correct punctuation to reply)
>>[/color]
>[/color]
gburnore at DataBasix dot Com
How you look depends on where you go.
Gary L. Burnore | ÝÛ³ºÝ³Þ³ºÝ³³Ýۺݳ޳ºÝ³Ý³Þ³ºÝ³ÝÝÛ³
Official .sig, Accept no substitutes. | ÝÛ³ºÝ³Þ³ºÝ³³Ýۺݳ޳ºÝ³Ý³Þ³ºÝ³ÝÝÛ³
| ÝÛ 0 1 7 2 3 / Ý³Þ 3 7 4 9 3 0 Û³
Black Helicopter Repair Services, Ltd.| Official Proof of Purchase
