Toyota Nation Forum : Toyota Car and Truck Forums - View Single Post - 1995 corolla--need maintenance tips
View Single Post
Old 03-28-2006, 10:18 PM   #8 (permalink)
Ray O
Guest
Posts: n/a
View Ray O's Photo Gallery
Re: 1995 corolla--need maintenance tips
"Gord Beaman" <gord@islandtelecom.com> wrote in message
news:k3vj229mm6cld7abp9n7n6ort1dusr9875@4ax.com...[color=blue]
> "slatt333" <slatt333@yahoo.com> wrote:
>[color=green]
>>okay, will follow your advice---just hope I never get water in the gas
>>tank[/color]
> Which raises a question...you can add 'gas line antifreeze' to
> your automobile fuel tank in the winter...this 'handles' the
> problem of a frozen fuel line. How does that work?, does the
> substance mix with any water in the line and prevent it from
> freezing?, or does it cause the water to be consumed somehow?...
> -Gord.
> (use gordon in email)[/color]
Yes and yes. Water doesn't mix with gas but it does mix with alcohol, which
has a lower freezing temp than straight water. The water/alcohol then gets
burned in the engine. The alcohol also has a tendency to eat rubber, which
tends to gunk things up.
Ray O
