Re: 06 TUNDRA - ADD A LEAF OR AIR SHOCKS?
"rich" <rock_fish@hotmail.com> wrote in message
news:pan.2006.04.02.07.38.54.603041@hotmail.com...[color=blue]
> Thanks Ray and Bruce for the education. Guess I'll have to take some
> measurements prior to the air bag install to ensure that I'm not inflating
> them beyond my normal ride height.
> rich
>[/color]
You're welcome! Come to think of it, I'm not really sure if a truck
equipped with ABS even has a load sensing proportioning valve (LSPV),
although our Previa has both ABS and an LSPV. You can check easily enough
by crawling under the back end of the truck and following the brake lines
from the rear wheels. If it has an LSPV, you will see the left and right
lines pass through a device mounted on a crossmember above the rear
differential that has a thin metal rod angling down and attached to a
linkage on the rear axle. If the brake lines just snake up to the front of
the truck, then there is no LSPV.
Enjoy your new truck!
Ray O
