Toyota Nation Forum : Toyota Car and Truck Forums - View Single Post - Celica Flasher relay
View Single Post
Old 04-12-2006, 10:46 AM   #2 (permalink)
Bruce L. Bergman
Guest
Posts: n/a
View Bruce L. Bergman's Photo Gallery
Re: Celica Flasher relay
On 12 Apr 2006 03:50:07 -0700, "Coyoteboy" <coyoteboyuk@hotmail.com>
wrote:
[color=blue]
>Having pulled this out due to 'disco flash' syndrome with all bulbs
>fine, on both indicator directions including hazards, I found it to be
>microprocessor controlled. Toyota want a monsterous amount for it,
>anyone got a diagram of it as I'll just make a new one?.[/color]
I'd have to check the wiring diagram for any unusual things, but
I'll bet you can drop in a standard USA'n Heavy Duty flasher.
Especially if it's a 2-wire system with Power In, Flash Out, and
possibly a Ground reference lead for the timing electronics that a
standard flasher will not need.
If you see more than three wires, stop.
DO NOT cut the plug off the wiring harness, make adapter wires from
male-tab and female-tab crimp connectors. You may want to put it back
the way you found it.
--<< Bruce >>--
Bruce L. Bergman, Woodland Hills (Los Angeles) CA - Desktop
Electrician for Westend Electric - CA726700
5737 Kanan Rd. #359, Agoura CA 91301 (818) 889-9545
Spamtrapped address: Remove the python and the invalid, and use a net.
