Re: Change Air Filter
"Michael" <Michael@displayitpockets.com> wrote in message
news:Iz0%f.4786$vy1.1767@news-server.bigpond.net.au...[color=blue]
>[/color]
<snipped>
[color=blue]
> Thats a good point, come to think of it, where would I put the air flow
> sensor? I'm thinking it would be after the filter?
>[/color]
The wire harness to the mass air flow sensor is probably not long enough to
allow much movement, and I never recommend cutting factory harnesses because
they are so expensive to replace. The sensor should be after the filter
because it has to measure the air actually getting into the intake and you
don't want it subjected to any debris that enters the intake. Bottom line,
whatever you rig should not disturb the current location of the MAF.
[color=blue]
> Also, if I got a 3inch filter and got an exhaust place to get a 2 1/2inch
> pipe, flare it at one end to the 3inch, would that work? Or should I stay
> with the 2 1/2?
> -Michael-
>[/color]
That would work although it seems like a lot of trouble.
Toyota Racing Development (TRD) is a Toyota affiliate and has stuff that
carries a warranty backed by Toyota. The web site for their U.S. operation
is [url]http://www.trdusa.com/[/url] You might want to check and see if TRD sells
products in your area. They may have an application specifically designed
for your car and you know it won't mess up the car.
Ray O
