Plenum removal points for Gen2 V6 Camry
Hey man, I do not know if this will help you, but I have taken my plenum off like 3 times now and after the first time I labeled all the connections so I can print 'em out and cross 'em off as I put it back on (also color-coded the connections with multi-colored electrical tape and a Sharpie but that will not help you). We have a 1990 Gen2 V6 Camry (automatic) and the things I have to disconnect to take it off for back plugs/valve cover/PCV valve are:
(type of connection or size of wrench/socket --- amount --- description)
Backside of plenum (middle area of rear)
12mm 2 EGR mounting bolts
14mm 1 Back plenum anchor (near lift point)
Vacuum 1 Medium vacuum line at middle rear of plenum
Passenger end of plenum
12mm 1 Bolt for passenger side grounding wire
12mm 1 Nut for passenger side grounding strap
12mm 1 Bolt for passenger side wiring bundle support (bottom area)
12mm 1 Fuel line bolt on passenger side
Spring 1 Fuel line electrical connection
12mm 1 Fuel line support bracket (bolts to pass side of plenum)
Vacuum 2 Small vacuum lines at passenger end of plenum
Vacuum 1 Medium vacuum line at passenger end of plenum
Vacuum 1 Big vacuum line at back corner near motor lift point
Working toward front side
14mm 1 Bolt for motor mount support arm on top edge of plenum (2 at base to loosen)
Front side, middle area
10mm 1 Bolt for throttle cable bracket (on middle leg of plenum)
14mm 4 Plenum mounting bolts(2) and nuts(2)
12mm 1 Nut to release throttle cable at first point
14mm 1 Nut to release throttle cable at second point
Vacuum 1 Big vacuum line from underneath plenum (from PCV)
Vacuum 1 Little vacuum line from underneath plenum (from PCV)
Driver side, air intake duct area
Hose 1 Line to plenum from front cylinder bank (EGR connection)
Hose 1 Small coolant line under air intake end of plenum
Vacuum 5 Small vacuum lines at "tree" of them, air intake end of plenum
10mm 2 Clamps to secure duct from air intake to plenum
Hose 1 Large hose from air intake duct to plenum
Hose 1 Medium hose from air intake duct to plenum
Vacuum 1 Small vacuum line, joins plenum to canister below master cylinder
Vacuum 1 Medium vacuum hose in front of gray electrical connection
Connection 1 Gray electrical connection near air intake end of plenum
Connection 1 Black electrical connection near air intake end of plenum
12mm 1 Bolt for driver side wiring bundle support (hidden under gray elec. conn.)
14mm 1 Back plenum anchor (next to wiring bundle support)
I hope this helps you - I can now take mine off in like 45 minutes no sweat
