Toyota Nation Forum : Toyota Car and Truck Forums - View Single Post - Electrical Troubleshooting Problem
View Single Post
Old 04-17-2006, 08:28 PM   #5 (permalink)
Jeff Strickland
Guest
Posts: n/a
View Jeff Strickland's Photo Gallery
Re: Electrical Troubleshooting Problem
"Travis Jordan" <no.one@no.net> wrote in message
news:SPy0g.141403$nk.49361@fe04.news.easynews.com...[color=blue]
> Jeff Strickland wrote:[color=green]
>> If I connect my volt meter properly, it can tell me the current that
>> is available -- I haven't done this test yet. I would expect to see
>> something in the range of 10 amps (this is the rating of the fuse) to
>> make the lamps come on. If I only see 0.5 amps, this would seem to
>> support my theory of a bad switch. Is that right?[/color]
> If you connect your "volt meter" to the ampere current range and connect
> it to the socket, you will blow the fuse. And you might even fuse the
> intermittent contact on the reverse switch, if indeed that is the
> problem.
>[/color]
That's correct. But if I connect my volt meter properly, I'd be using the
ameter sockets and selection on the meter's dial ...
