08 TSB's - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Truck, SUV and Van Forums > Highlander Forum > 2nd Generation (2008-2013)
2nd Generation (2008-2013) Forum dedicated to the discussion of 2nd generation Toyota Highlanders.
Old 01-31-2011, 02:02 PM   #1 (permalink)
View ECrepeau's Photo Gallery
08 TSB's
Have an 07 Tacoma so am familiar with the run around a dealer can give you with getting certain TSB's done. With that being said I am buying the wife an 08 Highlander AWD.
What TSB's are on the 08 Highlander that I need to check for? I am going to have the dealer perform any of the TSB's needed on an 08 as part of the purchase deal. Link, TSB # or name\description I can search for would be great.
ECrepeau is offline   Reply With Quote
Old 01-31-2011, 03:06 PM   #2 (permalink)
Senior TN Member
summerwind's Avatar
Gameroom cash: $624380
View summerwind's Photo Gallery
Look on http://www-odi.nhtsa.dot.gov/tsbs/
Some that may be worth knowing about.
TSB-0314-09 HVAC system oder
TSB-0321-08 Oil Leak from Camshaft Housing
TSB-0229-09 Brake Booster Rattle/Buzz Noise
TSB-0331-08 False Security Alarm Operation (the alarm goes off for no reason = bad hood latch switch)
If you hear a clunk when you turn a corner sharply it is probably the intermediate steering shaft needs to be replaced.
And the BIGGY...The recall on the VVTI oil line. You should find out if this has been done.
This is the only one the dealer should check for.
The other ones I mentioned are only for point of awareness and are VIN specific.
The dealer can run your VIN to determine what Campaigns are specific to your HL.
TSB's are bulletins for service techs and not recalls but it helps to be aware of what is out there in case you have an issue to see if it is covered.
Also might check out the sticky ***READ FIRST*** Common Problems/Questions & Solutions
2008 Highlander Limited AWD, Silver, SmartKey, VSC/TRAK, Bluetooth, Remote Start, No Nav, Tow package/hitch/color matched fascia, roof rack cross rails, Color keyed mud guards, Camry trumpet horns
summerwind is online now   Reply With Quote
The Following User Says Thank You to summerwind For This Useful Post:
TrailDust (01-31-2011)
