2010 Highlander Radio swap with 2011-2012 unit - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Truck, SUV and Van Forums > Highlander Forum > 2nd Generation (2008-2013)
2nd Generation (2008-2013) Forum dedicated to the discussion of 2nd generation Toyota Highlanders.
Old 01-30-2012, 08:13 PM   #1 (permalink)
View HomerSaysDoh's Photo Gallery
Lightbulb 2010 Highlander Radio swap with 2011-2012 unit
I just picked up my new company car, a 2012 Highlander. I also bough my former company car, a 2010 Highlander. I hate the 2010 radio, short display of satellite radio info. The 2012 unit is much nicer and the Bluetooth is nice too. Is it possible to buy a 2011-12 unit to install in my 2010? I have XM already installed and it is a non-JBL unit. Any help is appreciated.
Thanks to all who posted, both of my vehicles have interior LEDs as well as a real "beep-beep" horn. The Weather tech liners are great too.
HomerSaysDoh is offline   Reply With Quote
Old 01-31-2012, 11:15 AM   #2 (permalink)
Gameroom cash: $147500
View nogo's Photo Gallery
Very interested in this as well. Unfortunately we would need to buy the headunit from the dealer and will need to pay exorbitant prices.
For bluetooth you would need to buy a separate module for the headunit and you will have to wire the mic.
1997 Jetta GLS, 2007 E280 4Matic, 2010 Highlander Sport
nogo is offline   Reply With Quote
Old 01-31-2012, 05:01 PM   #3 (permalink)
If I can get a replacement headunit...will I be able to get full XM song info with the 2011-12 unit? I guess I can take out my 2012's radio and compare the wiring in the back. Was trying to avoid that if possible.Bluetooth would be nice, but secondary for me.
Old 11-25-2012, 09:15 PM   #4 (permalink)
View firenresq77's Photo Gallery
Anyone else looked at doing this? I have a 2008 HL and my dad has the 2012. I like the newer stereo much better. i also like the fact that he has the USB connection, not just the AUX jack.
I've found some of the newer radios on ebay, but most don't have the same specs as mine. I have the 6-CD Changer in mine, but the only ones with that on ebay say they are for the JBL system, which I don't have. The one's I have found without it are only single CD.
Also, I would like to get the USB connection.
Am I better off going to an aftermarket stereo to get all of this? Can I still use my steering wheel controls?
firenresq77 is offline   Reply With Quote
Old 11-25-2012, 11:07 PM   #5 (permalink)
Release the Mods!
sweeneyp's Avatar
Gameroom cash: $889686
View sweeneyp's Photo Gallery
to TN!
I don't think it will be plug and play. I have the wire diagram for the 2008-2010, but not the 2011+ (they should be mostly the same). But one of the members here (horent135) has recently informed me that apparently the 2011+ radio has a 5th connector not present on the 08-10. I don't know what that connector is used for. (EDIT: just thought of this, it could be for the new USB input, that would need 4 new wires into the headunit.) Apparently XM is built into units (it has an antenna jack) now so you won't need a tuner like on the 08-10's.
In terms of cost, aftermarket would be the best bet. You could probably get a 2011 OEM one to work, but you might have to get clever with the wiring (along with getting your hands on a 2011+ wire diagram for the radio). I'm not sure if they changed how the steering wheel controls work (I doubt it as other systems use it besides the radio), so maybe? but you can definitly get adapters for aftermarket headunits. If you see those adapters fit 08-2013 HL's, then I guess you can assume your 08 controls with work with the 2011+ headunit.
and on a random note, I had a 2 day subscription to TIS 3 days ago working on an old Lexus...I should of grabbed the wire diagram for the 2011 radio I'm an idiot
2008 FWD Highlander Limited<---Short---Modification List---Full--->CarDomain
sweeneyp is offline   Reply With Quote
Old 11-26-2012, 07:01 AM   #6 (permalink)
It is a direct swap for the 2012 unit in the 2010. The wiring harness is exactly the same.mi didn't add USB though. Just make sure to disconnect the XM antenna connector behind the head unit and plug it directly in the new unit.i did go from a 6 CD changer to a single, but the new hu was worth it. $50 on eBay and it was brand new.
Old 11-26-2012, 04:29 PM   #7 (permalink)
Thanks, Sweeney!
Homer, so youhad no troubles swapping out the 2 of them? I don't have the XM on my current HU so I just have a regular XM radio that I connect through the AUX jack.
Old 11-26-2012, 07:22 PM   #8 (permalink)
No trouble at all. The good news is, the 2012 hu has XM built in, so that's a plus for you. The eBay seller was out of Norwood, Mass. $50.00 and it was a new take - off unit. Steering wheel controls still work too
Old 12-22-2012, 07:30 PM   #9 (permalink)
View zeelander's Photo Gallery
Hi,
Does your bluetooth works? I got the 2011 head unit, but in my 2010 I have an extra harness that doesn't go anywhere on 2011-12 HU. If I take that harness off from 2010 HU bluetooth steering control doesn't work either. I got the 2011 HU for bluetooth streaming mainly. Many thanks in advanced. First post, recently switched from a 04 M3 to 2010 Highlander Sport.
zeelander is offline   Reply With Quote
Old 12-22-2012, 08:16 PM   #10 (permalink)
I don't have Bluetooth. I didn't have steering wheel controls for Bluetooth
Old 12-23-2012, 04:54 PM   #11 (permalink)
Thanks! Does anyone know the Faceplate # or the Part number for the 2011-12 JBL headunit, cd changer with Bluetooth ?
Old 12-24-2012, 10:32 PM   #12 (permalink)
bingo883's Avatar
View bingo883's Photo Gallery
Maybe swap in a 2013 radio panel face plate and use a aftermarket HU? Sweeneyp... It's calling you....
bingo883 is offline   Reply With Quote
Old 12-24-2012, 10:34 PM   #13 (permalink)
Release the Mods!
sweeneyp's Avatar
^ I think that is what Toyota had in mind. I think the OEM unit is a standard double din size. That way they could use it across all there models like they did.
Old 12-25-2012, 08:39 AM   #14 (permalink)
El Loco VG's Avatar
Gameroom cash: $248100
View El Loco VG's Photo Gallery
I bought an 08 Limited about 6 months ago and i love it only thing i wish i had besides hid lights is the Bluetooth. my wife has a 2012 Camry and the music streaming and phone are awesome. I thought of going with a blulogic but it only streams thru the two front speakers. Sucks getting older if i had this truck 5-7 years ago Id have hybrid tail lights mdx hid projectors mdx lenses so much potential so little money lol.
El Loco VG is offline   Reply With Quote
Old 12-25-2012, 11:24 PM   #15 (permalink)
Highlander #2
Gameroom cash: $509667
View AXMACD's Photo Gallery
does the new head units come in 6-disc?
2008 Highlander Sport V6 AWD (120k)
2009 Tacoma AC SR5 V6 4x4 (55k)
2008 Honda Civic LX-S (160k)
2002 Highlander Limited V6 AWD (SOLD)
AXMACD is offline   Reply With Quote
