How to replace driver side mirror case - Toyota Nation Forum : Toyota Car and Truck Forums
2nd Generation (2008-2013) Forum dedicated to the discussion of 2nd generation Toyota Highlanders.
post #1 of 2 Old 03-14-2012, 02:57 PM Thread Starter
Quoted: 0 Post(s)
(Thread Starter)
Need help replacing the passenger side mirror casing of my 2009 highlander.
Can i just pull it to pop out and put in the new one without having to loosen any screws?
Thanks
axa179 is offline
post #2 of 2 Old 03-14-2012, 03:19 PM
Resident Nutcase
sweeneyp's Avatar
Quoted: 1116 Post(s)
casing... are you talking about the painted portion? if so it is held in with 8 plastic "claws".
You can try and get it off by pulling/prying on it, but you will probably end up breaking a claw off. The best way to get it off (and the way the Toyota repair manual suggests) would be to remove the mirror, and you can manually disengage the claws from that side and the cover will slide right off.
Here is how you remove the mirror itself, its not that hard to do, I've done it twice now. All that holds it in is 4 clips.
Click Here for the Full List of Mods Done to My Highlander ---->>> 2008 FWD Highlander Limited
sweeneyp is offline
  Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Truck, SUV and Van Forums > Highlander Forum > 2nd Generation (2008-2013)
User Tag List
Linear Mode Linear Mode
Back
