2012 highlander base v6 (wire harness) - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Truck, SUV and Van Forums > Highlander Forum > 2nd Generation (2008-2013)
2nd Generation (2008-2013) Forum dedicated to the discussion of 2nd generation Toyota Highlanders.
Old 04-23-2012, 12:30 PM   #1 (permalink)
View justin38555's Photo Gallery
Hi all! I'm new to the forum and I have a question to all or anyone could help me out with installing off road lights. How do you wire 12volt (red wire) to, from the wiring harness, thankx a bunch
justin38555 is offline   Reply With Quote
Old 04-23-2012, 12:43 PM   #2 (permalink)
Release the Mods!
sweeneyp's Avatar
Gameroom cash: $884686
View sweeneyp's Photo Gallery
So you have a wire-harness (the whole 12v in, relay, ground, trigger input?) that has a 12v in terminal? that goes straight to the battery + terminal (only if it has an inline fuse). That is if I understand your question correctly
2008 FWD Highlander Limited<---Short---Modification List---Full--->CarDomain
sweeneyp is offline   Reply With Quote
Old 04-23-2012, 02:37 PM   #3 (permalink)
2012 highlander v6
thank you for reply! Yes, I have all the harness and all the wire hook up including the other red wire which is to the terminal. By the way! Sweeney, I have read alot of your mods, alot of work and excellent job of write up, thankx.
Old 04-23-2012, 02:54 PM   #4 (permalink)
Release the Mods!
sweeneyp's Avatar
Thanks ....so just to make sure, were you only asking about the 12v in wire, and your good to go now? Wasn't sure after reading your posts
